user interface problem
Hi I have UI.VI under a folder called DAQ and i have all my other VI's in the same folder. i can link to my Temp , Densiometry and Spirometry VIS but i connot link to my voltage.vi ? why ?
Message Edited by kmous on 08-22-2008 10:35 AM
LV 8.2
Message 1 of 14
(4,789 Views)
You have not provided any of the subVIs so your question is pretty much impossible to answer without pure guessing, which I'll pass on for now.
Message 2 of 14
(4,784 Views)
Why are you not able to link it?getting any specific error?Can u attach ur vis?
Message 3 of 14
(4,778 Views)
Can you attach ur vi for lv 8.0?
Message 4 of 14
(4,774 Views)
kmous wrote:
... but i connot link to my voltage.vi ? why ?
What is your definition of "link to"? I am not familiar with this term in this context.
 (How is the subVI setup? Could it be that it is configured to not show the panel?)
(btw, why do you think you need to write the panel color via a property 4x per second in a loop? Once is probably enough!)
Message 5 of 14
(4,763 Views)
Hello I will attach my folder soon. it is so big as a zip file , i will compress it and zip it.
For the Property 4x per sec , i will fix it 🙂 once my application works i will do another nice colored pannel.
Link to means when i select emg/force/scope from my menu  in UI.vi i want the voltage.vi to open up. 🙂
Message Edited by kmous on 08-22-2008 12:08 PM
LV 8.2
Message 6 of 14
(4,754 Views)
There u go
Thank you
LV 8.2
Message 7 of 14
(4,747 Views)
Go to the UI.vi and right-click on "voltage.vi". Now select "SubVI node setup" and check
  • Show front panel when called
  • close afterwards.
See if this helps.
Message 8 of 14
(4,743 Views)
Your voltage VI does not appear because of the Window Appearance setup in the VI Properties.
For your Voltage VI, go to the VI Properties->Windows Appearance, check the Customize radial, and click on the Customize button setup.  This takes you to the Customize Window Appearance.  Check "Show font panel when called" and "Close afterwards if originally closed".  Save the Voltage VI.  Hope this helps.
Message 9 of 14
(4,739 Views)
That worksssssssssssssssss thank you 🙂 🙂
LV 8.2
Message 10 of 14
(4,738 Views)
