use two indicators for the same variable in two different VIs
hello, I want to use two indicators for the same variable in two different VIs running at the same time
should I use global variables?? I want to avoid because I have lot of variables and it would takes too much memory,I tried with this code but the value of the second indicator is not updated
I tried to use the queue and it works but the problem is as i said previously that i have many variables shoud I use a queue for each one??
what should I do?
thank you in advance
cordialy
(2,958 Views)
I can't look at your code because I'm on my phone right now. Have you gone through the tutorials? If you have a lot of variable that may be your first problem. Many LabVIEW programs don't have any variables.
There is no best way to transfer data around within a program. The best solution (or sometimes the least sucky solution) depends on factors like timing requirements and overall architecture.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,942 Views)
I'm a huge fan of User Events to send updates to GUIs from who knows where.
(2,925 Views)
