use of FGV
Hello altenbach ,
As per your guidance i hope i am going good !!
i have done the same Vi using 2 methods
method 1 : using 2 shift registers
method 2 : using cluster ( i will use unbundle function and extract a required parameter in called vi's )
i have attached both vi's . is it right ?? gud ? review me
Message 21 of 23
(733 Views)
  • If a VI contains a typedef, you also need to attach the typedef here. (I seem to already have other typdefs in my download folder with the same name, breaking the code instantly). It is also a really bad idea to leave typedefs at the default name for this same reason. Give it a unique and intuitive file name!
  • You still have not implemented most of my suggestions.
  • Your cluster solution is not as I suggested, because you cannot write individual components, just the entire cluster.
Message 22 of 23
(720 Views)
Here's a lightweight example for the cluster method. This only works well if all data have the same type. (Else you would need a different input terminal for each type).
This is just a programming example to learn the tools of the trade. Nobody forces you to actually use it in production code. Again, why not keep using global variables? A FGV does not give you any advantage as we already tried to tell you.
Message 23 of 23
(713 Views)
