use of FGV
Hello all,
I have attached a file which consists of the global variable ( Model No ) .that is recalled in other programs too  I found that when writing the files in spreadsheet , race conditions are occurring. I know that we need to use an FGV to avoid race conditions. But I was in dilemma to create an FGV. help me to create an FGV for calling the (Model no) and ( test name)  in various other programs for the project
Message 1 of 23
(4,977 Views)
Hi bhuvanesh,
What was your "dilemma"?
Where are you stuck?
What have you tried? (Mind to attach your FGV VI?)
General hint:
- FGVs store data in a shift register (or feedback node).
- FGVs usually have an additional input to select the operation (read, write, init, …)
Message 2 of 23
(4,968 Views)
Hi gerdW,..
i have a attached a Vi . review that and tell me.. is it correct or not ?
if i want to use a ( model no ) or ( Test name ) in some other programs . How i should call ?
Message 3 of 23
(4,955 Views)
Hi bhuvanesh,
No, it's not correct…
- You have two cases/states where data is stored in the FGV - but there is no state to read the stored data!
- You store both items in the very same shift register "variable": either use two shift registers to store two items or store both strings in an array/cluster in one shift register…
Message 4 of 23
(4,945 Views)
no state to read means >>? sometimes i need to call " Model No " sometimes i need to call " test Name " . could you please develop a Vi and send me . i cant get you .
Message 5 of 23
(4,926 Views)
No. This is wrong. FGVs which just have a "get" and "set" method, like the one you are creating, do not do anything to solve race conditions (you are more or less making a global variable...). In order to solve a race condition, you need to put the functionality INSIDE the FGV (often these type of FGV are called Action Engines). The other ways to avoid race conditions is only writing the value once, then you know exactly what you are reading.
EDIT - looking at your JPG, I think you could probably solve your issue by using a wire instead of a global variable. Wires are good at preventing race conditions
Ian
LabVIEW since 2012
Message 6 of 23
(4,925 Views)
is this Vi ok ?? please read the previous conversations too .. i think you will get idea
Message 7 of 23
(4,917 Views)
No.  As said previously, that VI is no better at solving race conditions than a global variable.  In fact, you have just made a slow global variable that does not actually store the data.
A Look At Race Conditions
Action Engine
So let's take a step back.  Where are those values actually set?  Are they in the same loop or a parallel loop?  Do other loops need that data?
Message 8 of 23
(4,906 Views)
ya .  i need that data in other loops too . i need to call that in different vi's.
Message 9 of 23
(4,903 Views)
2 shift registers means ? 1 read case itself enough ? or  have to create 2  read cases ?
Message 10 of 23
(4,897 Views)
