upgrade bridge view FDS to PDS and Technical support
We have procured BridgeView FDS 2.1.1 and we would like to upgrade this to PDS and we are interested in builing the RunTime system to make the appplication program an executable file. Kindly suggest the rirht product for the above requirement.
Ours is a PIII computer with 128 MB RAM,20 GB HDD.
Can the BridgeView be used to access the network variables of the LON Builder Node (developed using neuron-c )from the network browser through the LON Manager DDE Server version 1.5. The same is working with Visual basic.Lon Manger DDE server is establishing link with Viual Basic and the same is not working with BridgeView.Please can anyone help
(4,196 Views)
The PDS version of BridgeView (or LabVIEW DSC) includes the application builder. This will allow you to build stand alone applications that can run on another machine. On the target machine you will need to have the run-time version of BV (or DSC) in order to have your tag engine work.
For the second question about setting up to communicate to a LON server. LabVIEW will support communication through OPC, DDE, Active X, Data Socket, as well as external comm methods like serial and GPIB. I'm not sure what problems you are experiencing with the LON manager DDE server, but using the DDE vi's in LV (or BV) you should be able to connect to a DDE server.
(4,196 Views)
