update txt file
Hello!
Can someone help and tell me how can i update a txt file, without dellet this or overwriting?
THANKS
Message 1 of 16
(4,208 Views)
If you are using the write to text file command all you need to do is use the Get File Position.vi and Set File Position.vi from the Advanced FIle Functions menu, this will allow you to append data to your file.  Let me know if you need more info.
Cheers!
Message 2 of 16
(4,201 Views)
Try this.  It's just what jmcbee said.
Message 3 of 16
(4,196 Views)
I don't know how.. I've never used labview..
can you send me an example, demonstrating how to do this...
thanks
Message 4 of 16
(4,194 Views)
GGT , can you send again the example.. I can't open it.. my version is the 8.0
thanks
Message 5 of 16
(4,191 Views)
Can't save to 8.0.  Here's an image, though.
Message 6 of 16
(4,185 Views)
thanks for your help!
now i have another doubt. i have a table with my data in txt file, that i want to compare with the data that i receive from the serial port type 1: if the value that i receive from the serial port matches the onde that i have on my table, it shows the name; and if i receive two values, i only want to show thw first one. can you help me dp this? perhaps with an example.. i´m only starting to learn the concepts
and do you think i shoul do this wiht a file or a matrix?
thanks for all help
Message 7 of 16
(4,161 Views)
thanks for all help
Message 8 of 16
(4,160 Views)
Hi!!
Can soemone please help me with this..
I don't understand much of labview.. I'm only starting to learn now..
Thank you very much
Message 9 of 16
(4,135 Views)
hi!
can someone please help with this... and give an example..
i can explain again my doubt if you didn't undersatnd..
thanks all
Message 10 of 16
(4,113 Views)
