pda
Is there any option for not using the Express-VI -Trigger and Gate-, but having the same result?!
It is because i am at programming a VI for my PDA at LabVIEW 7.1, but there it is not available!!
I only need it for defining a Trigger Signal, so there has to be another solution...
Thanks for every help!!!
Thomas
(4,709 Views)
Hello Thomas,
if you want to use similar the same code as the express vi use it, you could choose the settings you need in the configuration window of the Trigger and Gate.vi after that, close the window, right click on the vi and choose "Open Front Panel" after that you can find the used code. Modify and copy it into your vi. This must be work, but its not the best way. Try to use the given vi´s in the function palette for trigger.
Hope this helps, best wishes
Jan Kniewasser, Applications Engineer NI
Jan Kniewasser | Applications Engineer | Tel.: +49 89 7413130 | Fax: +49 89 7146035
(4,641 Views)
