update plot after each iteration
I have a sample code of data where I collect data over various devices.  Can you help me to update 'GRAPH 2' to show all the plots on that graph.  However, I would like GRAPH 2 updated after each completed run of the outer for loop.  [So after the 3rd iteration of the outer loop (defined by 'outer loop'), 'GRAPH 2' should have 3 plots and so on...]
hiNi.
Message 1 of 12
(6,662 Views)
Move the bundler in the inner loop to outside the loop and wire to it an array of x values (top terminal) and an array of y values (bottom terminal). Wire the resulting cluster to graph 1. Also accumulate this cluster into an array and wire it to graph 2.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 12
(6,650 Views)
I tried what you said, but I still can't seem to get it to work.  I can't get graph2 to update after each iteration, and also keep the last plots on the graph.
hiNi
Message 3 of 12
(6,632 Views)
I don't know about the regular XY Graph, but with the Express XY Graph there is an input called Reset.  If you wire a false to this it retains all the previous values.  I'm sure there's a property in the property node for XY Graph, but I didn't see one in the quick glance I took.
Tim Elsey
Message 4 of 12
(6,628 Views)
Accepted by hiNI
Hello hiNI
Do you want something like this?
Message 5 of 12
(6,620 Views)
EXACTLY WHAT I WANTED!!!
THANK YOU!!!!
Message 6 of 12
(6,615 Views)
Thanks for your help.!!!
I have one more request...
How can I dynamically change the plot names?  I extract a name after each iteration and would like to give the plot that name in graph's 2 legend.
Message 7 of 12
(6,596 Views)
This question was asked and answered in this other thread.
Message 8 of 12
(6,568 Views)
i am trying this for the following use to plot waveforms but not successful can anyone help
Message 9 of 12
(5,715 Views)
It is usually in everyone's best interest in posting new questions in a new forum post. This keeps forums focused on a single question from getting too long, and it will help you become more visible to get quicker help.
I attached a modified version of your code, though. There is some documentation included in it that should explain it a little more.
Best,
Shamik C
Applications Engineer
Message 10 of 12
(5,702 Views)
