update label names dynamically
I'm using LV 8.5,Is it not possible to assign label names(to say indicators) dynamically?
i remember(if im not wrong),it can be done in versions 7.1 or earlier.
Any suggestions?
Murali
(2,443 Views)
Use the caption instead of the label. this can be changed at run time with the property node.
the label is the widget's identifier, so being able to change it at run time would create interesting errors 😛
Message Edited by yenknip on 10-13-2008 05:25 PM
_____________________________
- Cheers, Ed
(2,442 Views)
