unload front panel
Hi all,
May I know how can I unload (not only hide it but unload from memory) a subvi's front panel? Let's say I have a main vi, and the subvi is shown when the button is pressed from the main vi.. Then how can I unload the subvi when the button is pressed from the subvi? And most importantly how I can pass the value from the subvi into main vi? An example for this will be highly appreciated.. THANKS!!
Message 1 of 9
(4,063 Views)
You can right click the sub vi icon in the main vi and chose Subvi node setup. Select Show Front Panel When called and Close After wards if originally closed.
To pass a value from a sub vi to the main vi, you need to have an indicator in the sub vi for the value you want to pass. Then right click the front panel's icon and chose Show Connector. Connect the indicator to one of the connectors. Afterwads, you may need to re-link the subvi in the main program before you can run it.
Hope these solutions help.
Message 2 of 9
(4,059 Views)
Can you pls create an example for me? as I was trying myself with no success. thanks.
Message 3 of 9
(4,057 Views)
Then how can I click the button from the subvi and it closes its own front panel?
Message 4 of 9
(4,054 Views)
Here is a set of vis for your reference. Try it out and let us know if you still don't get it. Please note that the attached vis are very simple and done quickly.
Message 5 of 9
(4,048 Views)
THANK YOU so much...!!! Smiley Very Happy This is what I've been looking for....
Message 6 of 9
(4,043 Views)
I hope you can give me some rating... Smiley Wink
Message 7 of 9
(4,035 Views)
Rating ?? how to give? I would if I know..
Message 8 of 9
(4,033 Views)
Each message has the entry "Rate message" on the right side, where you can select a number from 1(worst rating) to 5 (best rating).
Using LV8.0
Don't be afraid to rate a good answer... 😉
Message 9 of 9
(4,028 Views)
