07-05-2007 06:31 AM
07-05-2007 06:53 AM
Christine,
You may be seeing some sort of transmission error. When VISA encounters a byte of data that arrives with an error ( parity, etc ), it uses what is called an Error Replacement Character. The default just happens to be /00 (null). I suggest you change the default to some other character and see if you mystery character changes. This character can be changed by using a property node to set Property: Serial Settings : Error Replacement Character.
There may be some small timing differences between the two PC's that are affecting your vi.
One question, is the /00 an extra character in the expected data or is it replacing a character in the expected data?
07-05-2007 06:58 AM
07-05-2007 07:07 AM
Christine,
If you verify that it is a transmission error, then the hard part starts. What BAUD rate are you using? You could try slowing it down and see what happens.
07-05-2007 09:33 AM
07-05-2007 09:57 AM
Christine,
I was assuming that the TT20 could communicate at different BAUD rates. If the TT20 can only talk at 4800, then you are stuck at that rate. This rate is so slow that I really don't expect it to be the problem.
There can be all kinds of timing differences between different computers. Especially between laptops and desktops. That means that a potential source of the problem is the hardware handshaking and the DTR and RTS lines. Any chance that the state of one of these two lines is being briefly toggled at the wrong time?
So lets consider what other things might be different. You said this works on some computers and not on others. Are you using the same physical cable when you use different PC's? Are the laptops using a builtin serial port or are you using a USB-232 adapter of some sort?
Can you post a copy of your code that sends the command and reads the reply?
07-05-2007 10:08 AM
Centerbolt,
I can only assume they use the same physical cable. The one that was delivered with the TT20
But i am not sure
This whole constellation is in China at this moment, so i can't pop over easily to check things out -)
I will ask the responsibles over there, to answer this questions
Regards
Christine
07-05-2007 10:16 AM
Forgot to post the code
Christine
07-05-2007 10:52 AM
Christine,
Looked at your code. You are only setting the values of the DTR and RTS lines one place. That seems a bit strange based on handshaking schemes I've seen in the past. Do you have a copy of the communications spec for the TT20 you can post? I'd like to review the protocol.
I did notice that you are writing the property node in the same sequence frame as your time delay. The way this code is written, you don't know what will happen first. It could be the delay or it could be the writting to the property node. I am suspecting that this maybe part of the problem. What version of LV are you running?
07-09-2007 02:53 AM
Centerbolt,
I gathered a bit of info.
The same cable is used on desktop and portable
It seems to be an optical RS232
In attachment you will find the communications spec for the TT20. Not much to go on. But i am not a specialist on this.
I am using labv 8.2.1
You are right about the timing. I will make a version where i will make sure that the wait comes before the property node
Many thanks
Regards
Christine
