unable to delete user32.dll from support file list of application builder
In my application I'm using the system library user32.dll. Building an application (exe), the application builder automatically includes the DLL in the application. How can I remove the DLL from the support file list? The button 'remove file' is disabled and works only for manually added support files. My application will crash when using the copied user32.dll, instead of the library in the system directory. Until now I have to delete the DLL programmatically when I run the application...
(2,553 Views)
hi there
i don't see another solution than installing the dll in a temporary folder an deleting it afterwards. mybe you could try to use another installer than the built in.
best regards
chris
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
(2,550 Views)
