filtering noise from wave file
I have voice wave file that I would like to filter out the noise and amplify the speaker voice.  basically I want it to be a better quality.
If anyone can give suggestion of what type of filtering should I use and its cutoff frequencies, will be great.
thank you for your time
Message Edited by cube on 09-12-2005 06:22 PM
(2,589 Views)
hi there
the choice of the filter depends not only on the signal but also on the noise. i suggest to use the express-VI
Express -> Signall Analysis->Filter
to quickly set up a filter and play around a bit to find the best settings. as a start you could use a Bandpass-filter with a lower frequency of 100 Hz and a upper frequency of 20.000 HZ (about the range of the human ear, see attachment), or search in your data for pure noise (when noone is speaking) and make a spectral analysis of the noise to learn more about the filters settings.
best regards
chris
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
(2,573 Views)
