Showing results forĀ
Search instead forĀ
Did you mean:Ā
udp
i want to read data packets continously...
Message 11 of 17
(2,639 Views)
I have multiple IP series in 192.220.1.xx format in the local  network and all are sending in brodcast fashion with same remote port, but i want to read only from 192.220.1.22 in udp, how to read all the packets continously .....??? without missing packets...
Message 12 of 17
(2,636 Views)
Accepted by topic author Muniraju
Use. TCP/IP.
As you've been told UDP is not going to guarantee you get all packets continuously.
Also, did you say earlier you wanted 100 megabit per second?  With other things on the network?  What kind of network do you have, 100 Mbps or 1 Gbps?
100 Mbps on a 100 Mbps network is impossible.  On a 1 Gbps network is theoretically possible, but that is still a pretty heavy load for a single communication source.
Message 13 of 17
(2,617 Views)
So all these other devices are using broadcasts to saturate the network and you are trying to pick out messages from a certain source?
Broadcasts require UDP, they cannot go over TCP of course. Do you have control overt the remote systems or is their functionality fixed? What is the actual message rate?
Do you have some details?
All packets will arrive at your machine, that's the nature of broadcasts. Of course once a UDP transmission arrives, you immediately know the source IP and you can discard it if the source does not match. Are you listeing using "UDP multicast open" or plain "UDP open"?
What should happen to the accepted transmissions? Any further processing (stream to disk, parse out a single value, etc.)?
Alternatively, you could define firewall rules that only allow certain remote systems.
Message 14 of 17
(2,601 Views)
hii i have 100mbps network, and i am going to receive 156 bytes each time.....presently i  want to receive data using IP address without using Port Id in UDP(if port should be there means i want to receive only data which i entered IP address only)...
Message 15 of 17
(2,568 Views)
Hiii how to i know source IP once UDp transmission arrives....???????? I am using plain UDP open. The device which is coming from Data is functionally fixed...with network device rate is 100 mbps, im going to receive only 156 bytes.
Message 16 of 17
(2,563 Views)
Look at the help for the UDP Read function.  It tells you the IP address of the originating device.
Message 17 of 17
(2,545 Views)
