.txt file extension
Labview automatically saves a text file as a readable text file but it has no .txt or .text file extension on.  Is there a way in which you can make labview save a file automatically with a .txt file extension so it can be opened directly by notepad.  Rather than having to choose aprogram to open it with every time I try to access one of the files.
Matt.
Message 1 of 10
(9,444 Views)
The file write functions save a file with whatever name and extension that you provide. Nor does 'LabVIEW' automatically save a file in any type of format. The function that you choose will save in text or binary format. Explain what functions you are using and what parameters you are passing to it.
Message 2 of 10
(9,436 Views)
The quick and dirty way around this is to just type .txt at the end of your desired file name
ie, instead of "example" as your file name, type "example.txt"
Message 3 of 10
(9,424 Views)
Thats what we currently do but we need to do this for hundreds of files so it gets a bit annoying after a bit.  A way of doing this automatically would be good.
Matt.
Message 4 of 10
(9,410 Views)
Accepted by gilgad2000
gilgad2000,
It depends on your VI. If you are using the "Path Control" tool, you can open its "Browse Options" and write .txt at the Pattern box.
If you are not using it, you can also concatenate a ".txt" string at the end of the file path (use "Strip Path", "Concatenate Strings" and "Build Path" functions) just before using it on the saving function.
Message Edited by Danigno on 07-17-2009 03:18 AM
Message 5 of 10
(9,404 Views)
If you use the File Dialog.VI then you could wire the "pattern (all files)" with a string constant "*.txt". Running the VI will open the file dialog, which shows only *.txt files, and if you enter a name the extention txt will be automatically appended.
Message 6 of 10
(9,397 Views)
How can I do the path controll is I want to the user to select the path rather than to just write it to set place??
Matt.
Message 7 of 10
(9,391 Views)
I don't understand your last posting.
If the user shall select just the path for hundreds of files then you programmatically build the file path and append ".txt".
If the user shall select the disk location and file name then use the "File Dialog.VI" from the File I/O > Advanced file functions Palette as described above. You can also wire a start path for convenience of the user.
Jörn
Message 8 of 10
(9,384 Views)
When I say hundreds I meanmore like 10's.  They are normally saved in a similar place but in one of many folders.  Basically every time they save a reading it should automatically be a text file with the .txt file extension.
Matt.
Message 9 of 10
(9,378 Views)
Just managed top get it working.  The attached picture shows the code I used.
Matt
Message 10 of 10
(9,349 Views)
