trouble with database path (DSC)
I use DSC and LabVIEW 2009 in my application, and I created programmatically Shared variables, which have to be logged in Citadel database. For that, I create a database with Create Database VI with a specified path , and afterwards I use Configure Process Log State VI to bind values from my shared variables to the database.
The problem I have is the following: the database is created as expected in the correct path ( I have a folder created, with some .cdih , .cdin file), but after, on MAX, when I want to see trendings, i notice my database appears under Citadel 5, but nothing is inside. Actually, all my shared var are log in Default_database, the default database of DSC...Moreover, I have this event in Event Viewer (see attached image), which says
 I don't understand why i have such error...The problem is the final purpose is to create a standalone app with installer, and clients want to choose where they store their data...
thanks for your help
Antoine
(2,654 Views)
Hi Antoine,
could you please post you code and your LabVIEW Version?
Kind regards
Carsten
(2,602 Views)
