trial version restriction
Am using Lab view 2018 trial version. can trial version used for build exe program
Message 1 of 10
(5,607 Views)
I think so, but the application will have a watermark on the front panel indicating it is an evaluation version.
Message 2 of 10
(5,582 Views)
I actually don't think building binaries is allowed on a trial version, but don't have one to test with.  If it is allowed I too would expect watermarks.
Message 3 of 10
(5,562 Views)
According to the knowledge base you should have access to application builder but it will have a watermark as RavensFan said.
Message 4 of 10
(5,558 Views)
To be fair what I might have been remembering is the inability to create an RTEXE when the RT toolkit is a trial.
Message 5 of 10
(5,551 Views)
Can you Please tell me what does water mark mean actually?
Message 6 of 10
(5,522 Views)
yes i have the access of application builder but it doesnot work when i connect to my plc, can this issue because of my trial version ? Can you Please tell me what does water mark mean actually?
Message 7 of 10
(5,520 Views)
I have the access of application builder but it doesnot work when i connect to my plc, can this issue because of my trial version ? Can you Please tell me what does water mark mean actually?
Am using 2018 Lab view Trial version
Message 8 of 10
(5,529 Views)
I can imagine that a Trial Version might not let you build an application.  A Watermark refers to a way of "transparently" marking something (originally fine stationary -- hold it up to the light and it reveals the name of the Stationary Company) (in the present case, the Screen Images may show a light-gray overlay that says "LabVIEW Evaluation Version" or something like that).
Message 9 of 10
(5,508 Views)
Here is one image with an example of a Home or Student watermark which will appear on the front panel of every VI.
/t5/image/serverpage/image-id/166141i3062CD2062773A5F
For a trial the text will be different.  Functionally it should be the same and so if it doesn't connect to your PLC, upgrading to a full license won't effect that.
Message 10 of 10
(5,489 Views)
