transmitting and receiving parameters
Hi
i want to transmit a signal with minimum power that will penetrate a wall made of wood(4mm), hit the target and receive the reflected signal at the receiver.
Because If we used too much power then the object could essentially be missed by the transmitted signal.
Can you help me to set the best parameters to achieve that ?
the required parameters are :
IQ rate
carrier frequency
gain
timeout
tone frequency
tone amplitude
waveform size
number of samples
I am using two Comet SMA-703 (440 MHz or 1200 MHz) antenna and USRP 2920.
Thanks ...
(2,596 Views)
Hi TBH,
This sounds like some kind of electromagnetic problem. Do you have a specific LabVIEW programming question?
(2,581 Views)
