parameters of NI USRP 2920
I'm Using tow NI USRP 2920 devices and two VERT 400 antenna and we intend to transmit a signal that is going to penetrate a wooden wall of 4 mm thick. what are the parameters of the of transmitted signal should be ?
As we know that if the power of the signal is high it's also going to penetrate the target  and miss the target. My question is how much the following parameters should be  :
- IQ rate
- Carrier frequency
- tone frequncy
- waveform size
- number of samples
(2,491 Views)
(2,477 Views)
