transfer array values from labview to excel
Hello guys,
Now I have a magnetic field measurement system, I need x, y, z axis value and magnetic field value on my excel file. Then I think the 'generate from template' example might work for me. However, when I generate array, my excel data also shows the index of the array. It shows like this:
This is my block diagram, anyone knows how to eliminate the index value on excel?
(3,048 Views)
Hi zyb,
The express VIs will always give the array index (the config and generate report) express VIs. Unfortunately, there is not a way to remove this. However, as you are using that VI, it means you must have access to the report generation toolkit. I would recommend using the lower level Report Generation VIs - Namely 'Append Table to Report.vi'
(3,046 Views)
Accepted by zyb1003
I solved this problem. You can convert the array to string, then there is no index.
(3,016 Views)
