traditional ni daq using tbx 68t with error 10685
Hi im new, I have tried to create a program that will allow me to accept temp readings. i have a tbx 68t device and a pci 4351 card from which this is read.
I have uploaded the vi.
i keep getting a message of 10685 - the clock rate exceeds the boards recommended max. rate, even when i have the clock rate to a low 10.
any help is much appreciated, i am fairly new to daq with labview. i do appolgise i have yet not annotated on the program.
Notay
(2,448 Views)
Hi again Notay,
The 4351 Device has specific rates that you can sample at for single or multi-channel acquisition. There are six possible reading
rates – 10, 50, and 60 readings/s in single-channel acquisition mode and 2.8, 8.8, and 9.7 total readings/s in multiple-channel acquisition mode.
See the data sheet or manual linked bellow for more information.
http://www.ni.com/pdf/products/us/2mhw296-297e.pdf
http://digital.ni.com/manuals.nsf/websearch/9249394DFC45FA3D86256FD20078D836
Jon B
NI Uk & Ireland
(2,433 Views)
cheers mate!
Notay
(2,419 Views)
