traditional ni-daq examples
Hi im new to labview, are there any examples available for traditional ni daq?
i am trying to measure temperature throw a tbx68t device into a pci 4351 card.
Notay
(2,858 Views)
You can find many examples in "Help" -> "Find Examples...", this will launch the "example finder", then if you click on "Configuration..." you can select your board (PCI 4351) and find related example code.
Hope this helps
Epictetus
Antoine Chalons
(2,853 Views)
the funny thing is I have done that and i have limited the examples to be found just for my card 4351, but unfortunately there are no examples to be found.
could you please suggest something else?
thanks
Notay
(2,850 Views)
Hi Notay,
Have you installed the software for the 4351? You can download it from the following link:
http://joule.ni.com/nidu/cds/view/p/id/285/lang/en
You should then be able to access examples from the LaBVIEW Example finder under Hardware Input and Output>>NI-4351.
Jon B
Applications Engineer
NI UK & Ireland
(2,832 Views)
cheers mate, i will get back to you on that when i have downloaded it.
Thanks!
Notay
(2,812 Views)
