touch screen monitor
Stephen82 wrote:
What you mean about transparent?When connect Elo touch screen to your computer, LabView how process and how connect to screen to detect user action?Do you work with TCP/IP,UDP connection or OPC Server. Please give me some help.
It is has transparent as using a mouse.  It sounds have if you think this touch screen is more complicated than it really is.  When you use an LCD touchscreen monitor, it installs a driver into Windows.  That driver causes touching the screen to behave just like you were using a mouse.  Nothing more complicated than that.Smiley Wink
Message 11 of 26
(2,986 Views)
I know this is an old post but I don't want to start a new thread of the same topic.
It is possible to control two touch screen panels using the same computer?
Message 12 of 26
(2,568 Views)
Is it possible to control two touch screen panels using the same computer?
Message 13 of 26
(2,555 Views)
Why not?
Your graphics adapter has two outputs and every screen add another mouse to the system.
Gabi
7.1 -- 2013
CLA
Message 14 of 26
(2,541 Views)
Thanks. My next question is that is it possible to programtically place a pop-up window on extended monitor/ouput?
Message 15 of 26
(2,517 Views)
Yes it is, --> VI Properties 🙂
Message 16 of 26
(2,479 Views)
This in this thread the connectivity of PC to a touch screen monitor is discussed, is the procedure same if working with PXI running windows 7.
Also how to get to know if a touch screen monitor from any vendor is compatible with LabVIEW.
Message 17 of 26
(2,159 Views)
The things discussed in this thread are as valid now with Windows 7 has they were in 2008.
Message 18 of 26
(2,155 Views)
We use ELO touch screens. The Elo drivers act just like a mouse. So there is nothing special you need to as far a programming, except design your GUI with touch in mind.
=== Engineer Ambiguously ===
Message 19 of 26
(2,146 Views)
Hi everyone
I have a question regarding Touch Screen Monitor "TSM" product, as I am using one with cRIO system. I was hoping to get the pointer position as you would get mouse position on a Windows-based platform, but it seems NI has not provided anyway to access the pointer position or to get notified if the pen has been pressed (such as a mouse click on Windows based systems).
do you guys know what to do with this problem? any suggestions appreciated.
thanks
Message 20 of 26
(1,977 Views)
