top left corner of tab
Hello friends! Need your assistance again. Here's the problem ;
I want to find the top left corner of a tab (in a tab control). How may I do it?
Message Edited by C .DOT on 01-29-2009 06:47 PM
Message 1 of 10
(3,919 Views)
Hi C.Dot,
i think you can use a property node to read this information. I think inside of a tab the result is the position of inside the tab, so you have to add the position of the tab to the position of your control.
Mike
Message Edited by MikeS81 on 01-29-2009 02:50 PM
Message 2 of 10
(3,914 Views)
Relative to what? The "Position" property return the position relative to the window.
Or, are you trying to get the position in global coordinates? For that you need the mouse location, and the easiest way to do that is with the MouseMove event.
What do you need to do with this information?
Message Edited by smercurio_fc on 01-29-2009 09:10 AM
Message 3 of 10
(3,890 Views)
Relative to top left of the monitor screen. And I cannot use mouse move because I need these coordinates when user selects a menu item. With this information I need to display the screen of an executable whitin the tab (of course apparantly).
Message 4 of 10
(3,883 Views)
OK, I've read this 3 times and this still makes no sense. What does a mouse move have to do with selecting a menu item?
Message 5 of 10
(3,878 Views)
LabVIEW property node will return the coordinate of LabVIEW, you have to convert it to the window client coordinate, and then to the screen coordinate.
You can also make the executable a child window of your front panel.  So that it will move with parent window, and minimize with the parent window.
G Toolbox can do both, and you do have to move mouse.
George Zou
http://www.geocities.com/gzou999
George Zou
Message 6 of 10
(3,866 Views)
Accepted by topic author Rashid-Malik
Here is a method to retrieve the screen coordinates:
Good luck,
Ton
Message Edited by TonP on 01-29-2009 05:24 PM
My LabVIEW Ideas
Message 7 of 10
(3,860 Views)
Thanks TonP! Your wish did come true.
Accept my humblest thanks.
Message 8 of 10
(3,830 Views)
Thanks zou!
I will certainly try the toolkit when I can afford it.
Anyway thanks a lot for the advice.
Message 9 of 10
(3,827 Views)
Sorry ! For keeping you confused .
Still, you do deserve a big thanks for being patient .
Have a very pleasant day!
Message 10 of 10
(3,824 Views)
