toggle boolean buttons
How can I use one button to change the state of another and vice versa.
I have two buttons stop and start.
when I push the start button (condition goes true) I need the Stop button (condition is initially true) to become false.
Thanks in advance
James
Message 1 of 14
(10,986 Views)
Stop is  NOT Start and vice versa.
You can either use locals or property nodes to accomplish this.
André (CLA, CLED)
Message 2 of 14
(10,980 Views)
James, property nodes are one way to do this. Please see the attached example.
Message Edited by Chris_D on 11-29-2007 02:05 PM
Chris Delvizis
Message 3 of 14
(10,975 Views)
Chris,
I'm using labview 7.1 and can not open the vi
James
Message 4 of 14
(10,965 Views)
James,
Try using an event structure.  Capture the value change event for the buttons and when one goes true, set the other to false via a property node or local variable.
Greg Cole
“It is not the ship so much as the skillful sailing that ensures the prosperous voyage.”
Message 5 of 14
(10,960 Views)
James,
Try this one.
Jim
LV 2020
Message 6 of 14
(10,955 Views)
There is no need for any local variables, complicated logic and deeply stacked events.....
All you need is a radiobutton control. 🙂
Message 7 of 14
(10,941 Views)
An even simpler option would be to use a single boolean that contains a combo picture of the two states.
You only have exactly two states: (1) Start|Stop and (2) Start|Stop, right? So a single boolean can fully describe the overall state!
Here's a quick draft. No code needed at all! 🙂
Message 8 of 14
(10,934 Views)
Altenbach,
How did u make a single boolean object with two button (start/stop) appearance ?
thankyou.
Message 9 of 14
(10,913 Views)
He created a custom control and created and inserted 4 pictures for the different states of the boolean.
Although a very clean solution, the solution with some coding is faster to accomplish and more flexible if requirements change.
Message Edited by andre.buurman@carya on 11-30-2007 08:56 AM
André (CLA, CLED)
Message 10 of 14
(10,888 Views)
