Running yet Broken VI?!?!?
This is less a question/bug, more of something mildly amusing that happened earlier today yeah, it's both broken, but the abort button is lit, I can tell you for a fact that that VI is/was running when the screenshot was taken, and there was no photoshopping done. I also have one of a VI that is running, broken with the red pause on the front panel, and on the block diagram I can't pause, or even step over/through/in anything. extra points for someone who can tell me what I did. (I already know)
Message 1 of 27
(5,462 Views)
It's a clone? Or better a Zombie?
Ton
My LabVIEW Ideas
Message 2 of 27
(5,437 Views)
could be a clone.. (never heard of a zombie..  other than in some movies.. 😉 )
Under File Menu, select VI Properties, choose "Execution" for Category.  Within the Priority box, is it "subroutine"?
Or does the main vi call vi's that are set as subroutines?  Or are you calling vi's indirecty (dynamic code -- ie: executing vi's within given folder, etc)?
RayR
Message Edited by JoeLabView on 11-13-2007 07:41 AM
Message 3 of 27
(5,412 Views)
It's actually a VI which is called from within a class, and uses a typedef that is in the class, but the VI is not in the class itself.  (The controls are just there for the ride, it's easier to make a copy of a class that has 'public' types that way)
When the VI runs, it makes the VI in the class that calls it broken, as it should, but in 8.2 at least, if any VI within a class is broken, all of the class is broken, including any typedefs, causing the VI using the typedef to break, but only because it is running.
I had a good laugh yesterday when I came across that glitch.
Edit: The VI is being run on it's own, but in the end it will be called by the class.
Message Edited by Britoa on 11-13-2007 06:47 AM
Message 4 of 27
(5,408 Views)
I can see how this might be amusing, but to others of us it is a little more concerning.  It looks like a bug to me.
Is it possible for you to post a simple project with just the necessary class(es) / typedef(s) / VI(s) to reproduce this "VI which is called from within a class, and uses a typedef that is in the class, but the VI is not in the class itself" problem?
Message 5 of 27
(5,380 Views)
It could be a sub-vi, when the main vi runs, you can't run the sub-vi, because the sub-vi is controlled by the main vi, but you can stop the sub-vi.  The main vi must have a connection with the sub-vi.
------- LabVIEW 2009, So Easy, Even a Therapist Can Do It -------
Message 6 of 27
(5,368 Views)
I just tried to create the bug in a simpler VI, and I can't seem to reproduce it.  I will try again later, on my next break.
Message 7 of 27
(5,363 Views)
Alright, I managed to reproduce it.  It requires the following:
Parent class with a dynamic VI
Child class with an override of above dynamic VI, calling a VI not in the class
the child class must also contain a control/typedef, not of the private data.
the VI called by the child dynamic VI has to have the typedef in it.
To see the problem, just open the project and run untitled 2.vi  (it's just a while loop with a stop button)
This happens in 8.2, I am curious to know if it happens in 8.2.1 and/or 8.5
Message 8 of 27
(5,353 Views)
I can confirm it happens in 8.5.
Message 9 of 27
(5,347 Views)
Also confirmed in 8.2.1 ...
Message Edited by Steve.Briggs on 11-13-2007 01:40 PM
Message 10 of 27
(5,325 Views)
