toggle LED after time delay
I have a Control LED and an Indicator LED.
How can I set the Indicator to be False then after 5 seconds to be True again when the Control logic is True?
(5,542 Views)
Sorry forgot to mention when the Control LED is False the Indicator LED will be False
(5,538 Views)
See attached file
(5,516 Views)
KateB, That is an excellent solution.
Fantastic! Elegant code, really
You should write some explaination in. It actually beats the 'timed loop' usage. Many posts on the site are about this ina roundabout way.
Appreciated!
(5,266 Views)
Here's making it really flexible. All the hardwork from Kate makes it a sub-VI.
This one is set for 10 seconds. Stick a connector to make the time variable through the 'show connector'
(5,262 Views)
