to extract coordinate from an image
We are new to labview and are workin to extract a coordinate in (a,b) form from a subtracted image.The subtracted image in question has a single object shown.we need the image to be represented a s 8*8 matrix (0,0) to (8,8) (assigned manually previously)and get the location of that object as a coordinate ranging in this.
We need two sets of coordinates,one from where the object has moved from and the other,the current location of the object in the matrix defined.
please help
Message 1 of 8
(5,362 Views)
This can be done in a snap using IMAQ Vision. Do you have access to this package ?
Chilly Charly    (aka CC)
Message 2 of 8
(5,345 Views)
I did use IMAQ vision for the whole program.But im finding trouble extracting a coordinate in (a,b) form the way i need it.We only found options to get pixel coordinates not coordinated defined by the user.
Message 3 of 8
(5,320 Views)
you can get the cordinates of the mouse click if you are using the mouse during the process... Otherwise go to examples there you can have examples for selecting the ROI manually and finding the object and some other.. In corporate these things and try to get what you needed...
Smiley Wink
Message 4 of 8
(5,315 Views)
With IMAQ Vision, you can easily find the coordinate x,y of the center of mass and the size W,H of the picture. Then it's just a matter of scale calibration : the X coordinate is x*8/W, and the Y coordinate is y*8/H. So easy... Where are you stuck ?
Can you post a sample image ?
Message 5 of 8
(5,302 Views)
here is the sample image.i need to be able to automatically acquire the coordinates of the two black squares (the output should be of the form (0,0) and (1,3)).can you please help me with the vi?
Message 6 of 8
(5,292 Views)
Yes, I can indeed help you. This is a basic task (4 operations, one min job overall), so I suppose you are just discovering image analysis and LabVIEW (homework ?). No problem, but I prefer to help you rather than to do it for you.
Where are you stuck ? What have you been able to do so far ? Please, post your work, starting with the script developed with VI Assistant.
Message 7 of 8
(5,277 Views)
HI charlie, I had a similar problem. but in my case, I was able to open an image. What I want as my output is the x,y value when i move my mouse over my picture. i just cant seem to get this coordinate out for further analysis...could you help please?
Message 8 of 8
(4,787 Views)
