timing violations loop name doesn't exist...
This loop L73998316 is not in my code... I have this error since I added FPGA PID (fpga 8.6)..
any ideas?
Patrick
Status: Compilation failed due to timing violations.
The compile process reported timing violations in the following Timed Loops:
  * L73998316, using clock 40 MHz Onboard Clock
Suggestions for eliminating the problem:
  * For Timed Loops with timing violations
      - Reduce long arithmetic/combinatorial paths
      - Use pipelining within Timed Loops
      - Reduce the number of nested case structures
  * Reduce clock rates if possible
  * Reduce the amount of application logic to make routing easier
  * Recompile
Refer to the LabVIEW Help for more information about resolving compilation errors. Click the Help button to display the LabVIEW Help.
Compilation Summary
(3,523 Views)
HI Patrick,
Thanks for the reply and I hope your well today.
This error has been seen a few times before, however I am interested in your case as you appear not to have loop with that name, is that the case?
If you remove the FPGA PID - you dont see this error?
Pipelining has resolved several cases of this error in the past, pipeliningto optimize FPGA VIs link here - explains a bit more.
http://zone.ni.com/reference/en-XX/help/371599D-01/lvfpgaconcepts/fpga_pipelining/
Do you have any other timed loops - could it be possible that the name is just wrong?
Kind Regards
James Hillman
Applications Engineer 2008 to 2009 National Instruments UK & Ireland
Loughborough University UK - 2006 to 2011
Remember Kudos those who help! 😉
(3,498 Views)
Hi James,
I also had this error before and I solve the problem with pipelining and sometimes, just by recompiling make it worked (the achieved rate was really near the requested rate)...
But this time... since I added the FPGA 8.6 PID I have this error (name of timed loop timing violation). (35Mhz achieved vs 40MHz requested) but I do not find this timed loop name in my code...
Andrew from NI is working with me on this error ...
Andrew and I opened the FPGA 8.6 PID and there is 2 Timed Loop in the express VI, I'm currently trying to recompile with a 32 MHz clock do see if it will solve the problem...
Thanks for your help,
Patrick
(3,495 Views)
The compilation went successfully by changing the two Timed Loop inside the FPGA PID express VI to 32 MHz instead of 40MHz...
(3,479 Views)
Hi Patrick,
Good Morning and I hope your well.
Is this an Andrew from the UK Office?
I am glad you've managed to resolve this.. but does this mean you can't get your requested rate?
There does seem to be a CAR on this express VI for LabVIEW FPGA 8.5, so if you could either tell andrew or provide some more details of what the issue was I can submit one for LabVIEW 8.6,
Kind Regards
James Hillman
(3,466 Views)
I don't know which Andrew I talk to... (application engineer FPGA when i call to the 1800...)
As for the 8.6 FPGA PID express VI... I can't compile it, even alone in a fpga code... try it ...
Pat
(3,453 Views)
