timestamp conversion
In the attached LV2009 snippet, I use the "%d%b%Y %H:%M" to format the TimeStamp into a date/time that looks like this:  03/Dec/2009 10:33.  Now what I want to do is receive a string (in that same format) and stuff it back into a TimeStamp.  How can I do this?
Message 1 of 10
(8,477 Views)
Here is how I would do it
Tim
GHSP
Message 2 of 10
(8,470 Views)
That's not the format your VI creates. In fact, your strings look like: "txtHDate1=22Oct2009 06:45". Is the text "txtHDate1=" part of the input string? I also don't see any slashes.
Message 3 of 10
(8,466 Views)
Correction
Tim
GHSP
Message 4 of 10
(8,461 Views)
Accepted by topic author mrbean
My first example work witht the format that you are actually generating the second work with what you said you were generating.
Tim
GHSP
Message 5 of 10
(8,459 Views)
Thanks all for the extremely quick response.  That worked perfectly.
Message 6 of 10
(8,433 Views)
whats the name of  the function used here ? i am having problem finding it. Could cou attach this vi as attachment ?
Message 7 of 10
(8,055 Views)
It is scan from string
Tim
GHSP
Message 8 of 10
(8,046 Views)
It's the Format Into String function. It's in the String palette.
Message 9 of 10
(8,045 Views)
great! thanxx
Message 10 of 10
(8,039 Views)
