timestamp conversion
In the attached LV2009 snippet, I use the "%d%b%Y %H:%M" to format the TimeStamp into a date/time that looks like this:  03/Dec/2009 10:33.  Now what I want to do is receive a string (in that same format) and stuff it back into a TimeStamp.  How can I do this?
Message 1 of 10
(8,440 Views)
Here is how I would do it
Tim
GHSP
Message 2 of 10
(8,433 Views)
That's not the format your VI creates. In fact, your strings look like: "txtHDate1=22Oct2009 06:45". Is the text "txtHDate1=" part of the input string? I also don't see any slashes.
Message 3 of 10
(8,429 Views)
Correction
Tim
GHSP
Message 4 of 10
(8,424 Views)
Accepted by mrbean
My first example work witht the format that you are actually generating the second work with what you said you were generating.
Tim
GHSP
Message 5 of 10
(8,422 Views)
Thanks all for the extremely quick response.  That worked perfectly.
Message 6 of 10
(8,396 Views)
whats the name of  the function used here ? i am having problem finding it. Could cou attach this vi as attachment ?
Message 7 of 10
(8,018 Views)
It is scan from string
Tim
GHSP
Message 8 of 10
(8,009 Views)
It's the Format Into String function. It's in the String palette.
Message 9 of 10
(8,008 Views)
great! thanxx
Message 10 of 10
(8,002 Views)
