time stamp
I noticed an interesting case of using timestamp. I create my applicaiton in Window XP English version. When installed the created installer in French version, the generated current time has different order. In english version, it is month/date/year by default, but on the PC with French version, it is Date/Month/Year. Does any one have any idea on how to fix it? How could I find out the window version is french or English?
Ott
(4,395 Views)
The data itself does not change, only the representation is changed.
By default the representation is a local one (%z), to get a system independent time representation have a look at  the Time format codes.
Ton
My LabVIEW Ideas
(4,372 Views)
LabVIEW timestamp representations default to the SYSTEM time display format.  just change either the system settings OR create a strict type def that specifies the desired representation.
"Should be" isn't "Is" -Jay
(4,359 Views)
Thanks.
By the wy, I checked the Data and Time setting in the control panel. They are the same.
Where should I make the change?
Ott
(4,351 Views)
Accepted by Opt_Ottawa
In that case
Opt_Ottawa wrote:
Thanks.
Ott
You will need to make a strict type def to hold the display style.  Then replace each time stamp front pannel object with the type def.
(4,347 Views)
