time & date formatting
I'm user of LabView 6.1 basic
I have this question:
In the formatting number the Type Time & date
compare with 02:00:00,00 .How is posssible to delete the 02 and Insert the
correct date of the sistem clock?
Thank's Nicola
(2,961 Views)
You will have to do this Programmaticlly. The Format only puts the Number to show the Fomat of Time and Date you desire.
You can use the "Get Date/Time in Seconds" Function available under Time&Dialog Palette. Wire the Ouput to your Number Indicator Formatted for Time and Date. When you run the program the Correct Date/Time will be shown.
Good Luck!!
Mache
Good Luck!
Mache
(2,961 Views)
Thank's for the right answer, Mache
Nic
"Mache" ha scritto nel messaggio
news:506500000005000000F59F0000-1031838699000@exchange.ni.com...
> be shown.
> Good Luck!!
> Mache
(2,961 Views)
