thermotron
I looked at the block diagram.
To modify the other VI to use GPIB, Modify it to use VISA Read/Write instead of the old serial functions. Something like the attached file.
Message 21 of 25
(2,384 Views)
would you share the instruction set of S-1.2 chamber? i tried to search thru the thermotron website but couldn't find it.
Thanks.
James
Message 22 of 25
(2,037 Views)
I basically wrote a standalone application that can detects and replicates most of the basic functions on the thermotron touch panel. It is very simple by referring to the thermotron user manual and send the command thru tcp protocol vi library.
Take a look at the details of the complete project and snapshot below: (Vote for me if you think it's cool!)
https://decibel.ni.com/content/docs/DOC-18615
Message 23 of 25
(1,942 Views)
Are you done spamming these forums?
http://forums.ni.com/t5/Instrument-Control-GPIB-Serial/thermotron/m-p/2048534#M54337
http://forums.ni.com/t5/LabVIEW/thermotron/m-p/2048530#M668229
http://forums.ni.com/t5/LabVIEW/Thermotron-TCP-IP-interface/m-p/2048526#M668227
http://forums.ni.com/t5/LabVIEW/Controlling-Thermotron-Basic-steps/m-p/2048524#M668226
http://forums.ni.com/t5/LabVIEW/Problem-with-driver-for-Thermotron-8800-in-LabVIEW-8-0/m-p/2048512#M...
Message 24 of 25
(1,931 Views)
Apologize for the spam, I do tried with tcp/ip and it works with LV 10. Sharing attached student-level created subVIs for Thermotron 8200. :smileyhappy:
This can be a good reference point for user of other Thermotron series by referring to the user manual and replacing some of the instruction set with little modification.
Message 25 of 25
(1,917 Views)
