thermotron
in the attachment you can find the Labview driver I mentioned
thanks
Message 11 of 25
(2,484 Views)
As I suspected, that's an IVI driver and not a native LabVIEW one. Open any of the functions in the driver and you will see a Call Library Function Node. The dll being called is an IVI driver developed in LabWindows/CVI and the LabVIEW functions are just wrappers. Installation of the IVI Compliance Package is necessary for IVI drivers.
Message 12 of 25
(2,483 Views)
I have Installed it NI-IVI Compliance Package 2.3
what next?
Message 13 of 25
(2,476 Views)
In MAX while creating a new  Logical name
Whice driver sessions i need to choose?
Message 14 of 25
(2,475 Views)
I'm not sure that you need to do this unless you use IVI class drivers. With the compliance package installed, try running your VI again and see if you still get the same error. I'm also not sure how you do this manually anyway. For every IVI driver that I've downloaded, the setup program created all of this in MAX.
Message 15 of 25
(2,471 Views)
Greetings !
   In addition to what Dennis mentioned about the max configuration, you can refer to the following link that has additional information about setting it up in max. Extract the zip file and double click on ivi_max.chm that will  explain the MAX help for IVI.
http://digital.ni.com/manuals.nsf/websearch/2F01D02D9DA04FBC86256DC00065E716
Thanks and hope this helps
Best regards
Avi Harjani
Message 16 of 25
(2,450 Views)
The Thermotron 2800 is actually very easy to talk to using Serial Communications.  I wrote a set a VIs years ago that read basic information from 2800 or 7800 controller. I've attached these a copy of these VIs.  They won't do everything the IVI drivers do, but they are probably much easier to understand.
Alan Gleichman
Message Edited by Gleichman on 09-29-2006 08:36 PM
Message 17 of 25
(2,447 Views)
using GPIB what Port do i need to chose?
Message 18 of 25
(2,427 Views)
still thw same error
there were no creation of ant new driver at MAX
Message 19 of 25
(2,425 Views)
HI
HOW DID YOU REALIZE THAT THIS IS A IVI DRIVER ?
Message 20 of 25
(2,424 Views)
