취소
다음에 대한 결과 표시
다음에 대한 검색
다음을 의미합니까?
thermostat operation
O'k, I'm trying to purchase a thermostat that I can incorporate with a serial data/logger and complete my loop of climate control with the feedback.  Now, I know that some thermostats that are pc operable come with their own sensors.  Unfortunetly, I have to put this sensor to work since it's very costly and precise.  Just wondering if anyone has encountered such an issue, and if yes how do I tackle that.  Now I have a set of commands to which the data logger applies, but most of the programmable thermostats are controled via ethernet cable and don't interface with the serial (RS-232 stuff) all that easy.
Vadim
0 포인트
1/12 메시지
4,088 조회수
Vadim:
Googling "thermostat" + "RS-232" brings up lots of pages for thermostats with RS-232 and/or RS-485 interfaces.
With the information given, that's about all I can suggest for now, hope it helps.
0 포인트
2/12 메시지
4,078 조회수
I have used Eurotherm temperature controllers in the past.  They are very accurate, work with a variety of sensors, and can be ordered with serial communications.
0 포인트
3/12 메시지
4,068 조회수
As for information given, If u tell me what else could be helpful I would provide more.  As for thermostats with rs-232, I don't think I care about a thermostat being connectied throught the serial port, rather than ethernet port, I just want to combine the sensor at hand with thermostat I would purchase.  For that I envision that I would need some thermostat software that would be able to be scripted in order to control the sensor.  Or I would need a set of comand for the thermostat, that would enable me to controll it, and this way I could right some programm in Labview or VB.
Vadim
0 포인트
4/12 메시지
4,051 조회수
You need to tell us what sensor you have.
0 포인트
5/12 메시지
4,044 조회수
Googling "thermostat" + "ethernet" also brings up lots of products and links. Command set should typically be provided in the documentation for the device.
0 포인트
6/12 메시지
4,039 조회수
http://www.veriteq.com/validation-data-loggers/validation-humidity-specs.htm
Model 2000, temperature and humidity logger
0 포인트
7/12 메시지
4,035 조회수
I was pretty clear to the company I spoke to, that I need a command set to be able to do what I want (that's for the thermostat), and they won't tell me.
0 포인트
8/12 메시지
4,035 조회수
I'm confused.  What are you using the temperature data logger for?  You say you need a thermostat, but that implies a device that measures temperature and controls an output.
0 포인트
9/12 메시지
4,031 조회수
The thermostat needs to be calbrated by this sensor/logger; therefore, we don't care what the thermostat measures, and we are only interested in what the logger measures
0 포인트
10/12 메시지
4,028 조회수
