thermistor formula node
hello to all engineers!!
i  found the example mydaqthermistor which converts the  Resistance ( from daq) to Tempertaure Polynomial Equation..
i want to modify it and as an input for the resistance to have a 2d array of random numbers and as an input a 2d array ( for  every resistance value showing the temperature )
however i cannot find the correct modifications !!! i tried a for loop, i deleted the dynamic data converter i changed the output indicator but it constantly shows errors..
(3,500 Views)
Why would you use a formula node?
The Math Primitives are polymorphic over array size and dimensionality.  Then you don't need to figure out how to declare an array of NDims
"Should be" isn't "Is" -Jay
(3,483 Views)
Or you can use the Polynomial Evaluation.vi located in the "Mathematics"
(3,468 Views)
