the problem about calling .dll function
Dear All,
When I use call library function node to call a .dll function, but it cannot run. i don't know if the .dll function statement was shown as below and atach the program to your reference. Iit is very easy. I think i set wong the parameter type. But i cannot find it. would you please help me?Thanks!
flReadProgramFiles
int flReadProgramFiles(
    char * filename
Parameters
filename
string containing the directory and filename root. This function will generate the XPV and XDV extensions.
Return Values
non-zero on failure, 0 on success.
Remarks
This function is used to load the firmware files into memory.
Jimmy
(3,289 Views)
Try converting your string to a byte array.  This function is under the strings>>string array/array/path conversion palette.  Set up your call library node to take an array input of the U8 types with an array length parameter also.  Hope this helps.
BJD1613
Lead Test Tools Development Engineer
Philips Respironics
Certified LV Architect / Instructor
(3,267 Views)
Let's keep it all in one place!
Starting multiple threads with the same question does not improve the chances of getting a good answer, it just clutters up the forum.
(3,264 Views)
