Importing Max file
Hello all,
I have some requirements which to import the NI configuration
file to MAX programatically through Labview.
This config file contains the virtual channel informations which will
be updated to the particular physical channels while loaded.
So far i was able to import the config file manualyy using Max
Import/Export.
Can somebody tell me/send a code which will do the same???
Thanks and regards
Vijaysiva
(2,812 Views)
Hi Vijaysiva,
I think that this KnowledgeBase, How Can I Load or Change My NI-DAQ Configuration File (*.daq) Programmatically in LabVIEW? is just what you need.  It explains how to programmatically load the .daq files that you previously imported/exported from MAX.
Take a look at this document and please post again if you have further questions.
Good luck!
Megan B.
(2,800 Views)
