text ring strings not updating
This has always worked for me before, but not any more.  Smiley Surprised I've been at this for nearly half an hour. ?????
PaulG.
Retired
(3,407 Views)
it seems to be working for me???
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
(3,406 Views)
That's strange.  The values are in there you just can't see them. If I use the arrows it works, but when I expand the list I see empty names.  Though, when I select one it displays properly.  A head scratcher to be sure.
Tim Elsey
Certified LabVIEW Architect
(3,401 Views)
elset191 wrote:
... A head scratcher to be sure.
Indeed. Now I know I'm not crazy.
Smiley TongueSmiley TongueSmiley TongueSmiley TongueSmiley Tongue
PaulG.
Retired
(3,391 Views)
Accepted by topic author PaulG.
I think I fixed it myself. My data file was created in Excel, saved as a text file. I went back into the Excel file and made sure my cells were formatted as text only. Resaved, reloaded into this vi and it appears OK. What a strange symptom, though.
May I give myself kudos and solution if I do it myself? Smiley Happy
PaulG.
Retired
(3,382 Views)
You have nulls (\00) throughout the strings fed to the ring.  Remove  the nulls and I think you will see your strings.
Lynn
(3,367 Views)
Here is a code snippet which will remove the nulls.
Lynn
(3,363 Views)
