text from bitmap
I have a bitmap that will include a black and white picture and white text.  How do I find the text on the bitmap?
(3,825 Views)
Using LabVIEW's Vision Module on you should be able to apply an OCR to your image and extract the text. However, this will require you to purchase this module.You may be able to get hold of an evaluation somewhere.
Amit
(3,804 Views)
I use TOCR from Transym to get text.
(3,801 Views)
Hi Dennis,
    The link was very usefull,but it is not extracting this kind of text.
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
(3,696 Views)
Your question has nothing to do with LabVIEW and would be strictly a problem with whatever OCR program you use. If you are using TOCR, then I would suggest using the TOCR viewer to test the conversion. When I converted your .gif file to .tif and opened it with the viewer, the image was virtually unreadable. This may have been a problem with the .gif to .tif conversion but I really have no way of knowing that. With the viewer, you have various options you can experiment with.
(3,688 Views)
