text file calculation
Hi all,
How do u extract 2 to 3 fields from txt file and need to do caculation and save it on another file.
is there any example for this.
thanks
Message 1 of 11
(3,948 Views)
You can use file function and some string function to achive the target.
To get better idea about your requirement please share your tex file.
Thanks and Regards
Himanshu Goyal
Thanks and Regards
Himanshu Goyal | LabVIEW Engineer- Power System Automation
Values that steer us ahead: Passion | Innovation | Ambition | Diligence | Teamwork
It Only gets BETTER!!!
Message 2 of 11
(3,942 Views)
Thanks for the reply.
i need to actual value from 1 file with tolerence from another file and produce test result.
thanks
Message 3 of 11
(3,935 Views)
Hi 6878,
use ReadFromSpreadsheetFile with "|" as separator to get the individual values... Save likewise when needed!
Message 4 of 11
(3,930 Views)
Please find the attached VI
I made it for CL2_StSt_Info constant. You can do it pragmatically.
Thanks and Regards
Himanshu Goyal
Thanks and Regards
Message 5 of 11
(3,927 Views)
As gred Says you can also use delimiter with I.
Now no need for the for loop coding
Thanks and Regards
Himanshu Goyal
Thanks and Regards
Message 6 of 11
(3,926 Views)
Thanks for brief explanation. when i writing to spread sheet array , i need to add one more column along the columms which i retrieve from read from spreadsheet array? Is there any fn to concate 2 arrays thanks
Message 7 of 11
(3,899 Views)
Accepted by 6878
To concatenate two array you can use build array function with selection of concatenate array property.untitled.JPG
Thanks and Regards
Himanshu Goyal
Thanks and Regards
Message 8 of 11
(3,891 Views)
Is it possible to use string inside formula node.
if (x == 1)
result = Ok ;
else
result= "NOK"
tks
Message 9 of 11
(3,881 Views)
Hi tks,
why do you need a formula node for such tasks?
Btw. "NOK" is a string, while Ok is some kind of variable. Your text will only work, when Ok is defined as string...
And quickly reading the context help for the formula node would have shown that there is no specifier to define a string - just floats and ints!
Message 10 of 11
(3,879 Views)
