test sequencer
Hi guys
i am very new to Labview environment. i was looking for test sequencng program example and i landed up here. i have been trying to understand this test sequence but unable to understand how it works..please can you guide me through it.
thanks
kind regards
sandi
Message 11 of 18
(4,101 Views)
Have you read the documentation? Have you had any formal LV training?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 12 of 18
(4,068 Views)
To learn more about LabVIEW, I suggest you try searching this site and google for LabVIEW tutorials. Here and here are a couple you can start with. You can also contact your local NI office and join one of their courses.
In addition, I suggest you read the LabVIEW style guide and the LabVIEW user manual (Help>>Search the LabVIEW Bookshelf).
Mike is a fantastic instructor...   Very knowledgeable.. 🙂
Message Edited by JoeLabView on 06-16-2008 08:30 PM
Message 13 of 18
(4,057 Views)
thanks for your share these VI
i am try using the sequencer,but it only loop 1 time,无标题.png,this case resulting in the sequencer stop ,what is function of this VI(Error Handler (no log).vi) in the case?,and i am not sure this is ture in the false case!无标题.png
Message 14 of 18
(3,232 Views)
ArkadaÅŸlar merhaba,
Bu konu çok eski ama bir sorum olacak.
Ben bu Test Vi larımı çalıştıramıyorum
Message 15 of 18
(2,214 Views)
This thread is very old but I have a question.
I can't run these Test Vis
Message 16 of 18
(2,208 Views)
What I have done in the past is create a simple "Queued State Machine" where each "state" was a complete test to run. With a simple GUI that allows the end user to select what "tests" they want to run in what order.
=== Engineer Ambiguously ===
Message 17 of 18
(2,169 Views)
I'm currently working on our 3rd generation (we call it a test framework).  In some regards it's like TestStand, but tailored to our needs and much much simpler to use; especially the code module interface, and the deployment tool (deploying with TestStand is usually a big headache).  Creating the deployment tool has actually been the most challenging part of the project.  It's a very large project, comprising several hundred VIs.
Message 18 of 18
(2,142 Views)
