temperature stablization criteria
 Could anyone please send me an example of action engine that is illustrating my case? The one in the forum is not that explanatory.
 Which VI or VIs should I use to take the last 10 TC readings (and the 10 before that) and make calculations on them?I tried build array but it did not work.
 Thank you
Message 11 of 17
(1,072 Views)
deniz-
I spoke with Josh, my colleague, and he mentioned he has been working with you over e-mail.  I will defer to him to continue assisting you.  If anyone else would like to comment, please do so.
Mike S
NI AE
Message 12 of 17
(1,047 Views)
I saw your post one of the topics here in ni. I have a problem with my vi. I thought may be you can help me. If you can help pls send an e-mail to mguness@gmail.com. I will send my vi with problem.
Thanks in advance.
Best.
Message 13 of 17
(906 Views)
Here is an action engine to determine temperature stabilization per UL1778 Section 49
"Temperature change shall be less than 2 degrees C over 3 consecutive 15 minute intervals"
 You feed it a numeric array containing your measurments every 15 minutes to test for stabilization
You might have to change the High and Low limits depending on your aplication in the "Wirte" state.
I use this in a program for thermal testing power transformers and use redings outside of 0C and 200C as open thermal couples.
=== Engineer Ambiguously ===
Message 14 of 17
(898 Views)
Hİ, could you please converted it to the Labview2010. I culdn't open it. Best.
Message 15 of 17
(886 Views)
Here is a version in 8.0
Tim
GHSP
Message 16 of 17
(880 Views)
aeastet beat me to it... Smiley Sad
As I was saying lastnight you might as well remove the highlighted section in the attached JPG.
As I put this in to try and detect open or bad thermocouples.
Message 17 of 17
(877 Views)
