temperature difference
I constantly get temperatures from a sensor and I want to build the temperatures difference from the start temperature and each other temperature. The Problem is that my Sub VI is in a Main VI with a while loop so the 0 index of the array (with the temperatures) is not always the same. How can I save and use the very first start temperature T0?
Message 1 of 9
(3,448 Views)
Hi Deli,
The index "0" of an array will always be the index "0"…
Use a shift register for T0…
Message 2 of 9
(3,444 Views)
First of all thank you for your fast answer.
Then why do I get every second another Element. My Indicator changes constantly.
And I cannot use a shift register because I work in a Sub VI and I am not able to use the Main VI.
Message 3 of 9
(3,404 Views)
Hi deli,
Because with each iteration you create a new array made of one single random number...
What else do you expect from your code???
You can use shift registers in your mainVI as well as in the subVI. When you don't know this I recommend the beginner tutorials offered at the top of the LabVIEW board!
Hint: Examine the point-by-point functions to learn about (one way of) using shift registers...
Message 4 of 9
(3,400 Views)
Yes Sir that was my Point. i Need the very first Element of the very first Array.
I will try it with the Shift Register.
thanks a lot Mister Gerd!
Message 5 of 9
(3,375 Views)
Your code is senseless. Your loop is building a new array every iteration using a random number wired to all elements of the array. Your indicator called appended array is never an appended array. It will always be a three element array containing the exact same random value in each element.
I highly recommend that you go through the tutorials linked at the top of the forums page.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 6 of 9
(3,345 Views)
I Know that this is senseless. I just want do Show my Problem as you can See there is Not a Input of a Temperature sensor.
i just wanted to Know how I can Save and use the First Element of my array. I Need the temperature T0 and thats my Point. (I thought it should be the index 0 But this doesn‘t work in a while Loop)
I Hope someone understands me.
Message 7 of 9
(3,287 Views)
I Know that. I just want to explain my problem. As you can See there isn‘t any temperature inputs. That’s Just a VI that I Made to show my problem.
I want to Save and use the First Element of the First Array (everything Happens in a while Loop), Thats the start temperature T0. So I can calculate the temperature difference between the First and each other Element.
I Hope someone understands me now.
Message 8 of 9
(3,326 Views)
Accepted by DeliMB
Hi Deli,
Store the first element of the array to a shift register - but only in the first iteration of your loop!
You need a shift register and a case structure (or Select node)…
Or you measure T0 before your loop and just use a wire to feed it into the loop.
Or you build a statemachine with one state of "measure T0" and other states like "measure new values". Then use shift registers again…
Or…
Message 9 of 9
(3,311 Views)
