tektronix tds 3000 Invert Channel
I'm using the drivers to configure the oscilliscope between two experiments that I change often. I got everything to wor except there doesn;'t seem to be a function to set a channel invert on. There is a matjh function that claims to have some sort of invert but doesn't. Any help?
Also is there a simple way to just read configuration from the oscilliscope?
(2,614 Views)
Accepted by topic author TSCline
You can use the VISA Write function to send the CH<x>:INVert command (where <x> is the channel you want to invert. The MEASU? query will return the measurement parameters. Refer to the TDS3000 programmer manual.
Ben64
(2,608 Views)
