12-22-2011 11:06 AM
I'm using the drivers to configure the oscilliscope between two experiments that I change often. I got everything to wor except there doesn;'t seem to be a function to set a channel invert on. There is a matjh function that claims to have some sort of invert but doesn't. Any help?
Also is there a simple way to just read configuration from the oscilliscope?
12-22-2011 11:44 AM
