tcp/ip
hello,
      i have created client and server program, both i am running in same pc with same ip address and port no.
it is working fine but tcp/ip is connection orineted service if i remove LAN cable still it is transfereing data. then what is wrong with that.can any one please help me.
Message 1 of 11
(4,789 Views)
If it is same PC then what does LAN matters.What IP address you are using?
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 2 of 11
(4,788 Views)
if it is 127.0.0.1 then It will like this only
--Ranjeet
Message 3 of 11
(4,787 Views)
no it is 192.168.1.92                 and for this loop back is working or not.
Message 4 of 11
(4,780 Views)
What does it mean? You are telling or asking?
--Ranjeet
Message 5 of 11
(4,774 Views)
hello sir,
               hello sir i am asking .
Message 6 of 11
(4,772 Views)
This might possible it is communicating with self only as we cannot tell without seeing your VI.. Do one thing there are lots of 3rd party software which will send data over TCP to particular IP address(Make sure you are not is same network). Use this software and then read through lablivew.
This will verify your VI.
--Ranjeet
Message 7 of 11
(4,765 Views)
hello sir .
        i have attached my vi's. client and server respectively.
Message 8 of 11
(4,760 Views)
Can you upoload in 2011 format
--Ranjeet
Message 9 of 11
(4,755 Views)
hello sir.
    2011 format.
Message 10 of 11
(4,749 Views)
