table
this is what a made now but does not work only the first time the 2 data a written to the table
in the next row they appaer but when i click the always override the second row
sry for the stupid questions
Message 11 of 38
(2,504 Views)
tried now this and it works fine, the data comes each time when i pusch the add button,
but when ido empty table the table is cleared, but when i press the add button the previous dat appaers
normally i should start again from row 1 why looks the table empty and is not ?
in table property's i set empty table and reinitialse to default value.
would be greta i someone could help
Message 12 of 38
(2,484 Views)
Hi drek,
THINK DATAFLOW!
The table is just an indicator. The data is stored in wires and shift registers.
So did you really delete the data (in the wire) or did you just clear the indicator?
Message 13 of 38
(2,470 Views)
And put the Add button where it belongs - inside the event.
Message 14 of 38
(2,464 Views)
i think i just clear the indicator , gonna searc then how i can reset evrything in the wires
Message 15 of 38
(2,449 Views)
Use one more event to clear the data.
Drag and drop this snippet on LabVIEW block digagram window to get the code.
Munna
Message 16 of 38
(2,454 Views)
strange things happens now 🙂 here is what i did
Message 17 of 38
(2,439 Views)
Hi drek,
what is "strange"? What happens at all?
Why don't you attach the VI? Why do you attach just images?
What is displayed in the table?
Message 18 of 38
(2,434 Views)
the data jumps each time to a different place, i can clear the table with the button but still the previous data appears,
forgot to attach the vi 🙂 so here he is
Message 19 of 38
(2,413 Views)
1. You have multiple shift registers on top of each other.  That could make things interesting.
2. You do not need to have waits inside of your event cases.
3. Do you really want your loop to stop when you add an item to the table?  You probably want a stop button for stopping your loop.
4. Do not use switches for commands.  Use buttons (like the OK button).
Message 20 of 38
(2,402 Views)
