table
Dear all,
I have to read 2 number from an rs232 and everything is working, but what i wanna do is to put the 2 numbers next
to each ohter when i press a button, the numbers appaer in the table the first time the are in the good positio but
than no more:
should be like that:
12      13
28      41
ech time i press the button the numbers should appearon te next line
i made something but is does not work correctly, can someone help me
to find the solution.
Many thanks in advantage
Message 1 of 38
(5,629 Views)
1. Get rid of that FOR loop.  It is not doing anything for you.
2. You should create a 1D array of your two numbers and then append that to your table data.
3. I highly recommend keeping your table data in a shift register.  It will make your process A LOT more efficient.
Message 2 of 38
(5,560 Views)
thx a lot its working great !!!!!!!
Message 3 of 38
(5,537 Views)
I don't see any thanks!  Thanks should be given with Kudos and Marked Solutions.
Message 4 of 38
(5,526 Views)
damn 🙂 still something wrong, the numbers are next to each other but they keeps coming
first it should be like:
when a pusch a button
12  80
then if i pusch the button again the new numbers might appaer:
100  120
and so on
dont be to hard im a beginner 🙂
greeting and thanks
Message 5 of 38
(5,484 Views)
OK, now you need to learn about "event structures". There are some really good tutorials online.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 6 of 38
(5,462 Views)
ok going to read about event structures, mihgt be a good tip
if im trying something and it does not work ill post my block daigram here
thanks
Message 7 of 38
(5,454 Views)
So i tried the event structure, and this is what i made, it works might be not as others do but im new to it.
While running the program an do empty table and import new values the old values after empty table
appaers again ( strange), what i also tried is data operations make current value default but does not work,
can someone help me ?
Message 8 of 38
(5,396 Views)
No, none of that is correct. The event structure should contain the code you want to execute when then button is clicked. You have all of it outside the event.
Message 9 of 38
(5,374 Views)
Your code should look something like this.  Remember that the event structure will keep your loop from iterating until it handles an event.  So you want everything you want to happen when you press that button to be in that event case.  You cant' see it directly in this snippet, but I am also handling the Stop button's value change event and using that to tell the loop to stop.  You alos need to make sure your array is passed through all of your cases or you can lose your table data.
Message 10 of 38
(5,346 Views)
